Hi Guys,
I recently started using Veggie in my 2.4 1993 Surf it was Ok for a while but not I am getting a fuel leak from somewhere near the bottom RH side of the engine. The engine starts and runs reasonably well tickover is a bit lumpy even when hot but does'nt stop.
I started at 75% Veggie and before that ran out it had started leaking but only when cold at startup.
I then put in 100% veggie and fitted a water heated fuel heater but now I think it is probably leaking a bit all time I am running, it certainly leaks at startup and also at park. It is quite a fast leak for a few seconds when parked and engine turned off but does stop.
If I run parked up I leave a large pool of fuel on floor, so have to start and pull straight off.
I noticed that the pipe from the heater to the pump drains of fuel when parked but the engine does start OK bit lumpy till warm.
I plan on fitting a second diesel tank for stop and starts, do you think this will help or is this a sign of a knackered pump???
Regards John
PS visability down and under the side of the engine is not good so I am not sure where the leak is.
Regards John
