Well thats the idea!!!
  • Well thats the idea!!!
    Wot do ya think??? (like i care) will it look ok,
    3" s/s tube, two part brackets so i have a bit of adjustment, up/down, in/out,
    i'm looking for some sort of end cap's for em, wnated domed ones but i'm thinking "pet shops" small furry animals and parrot type s/s feeding dishes,
    any other ideas? tried google/ebay/wheel hubs etc,
    sorry Matt, still aint got the hang of this camera
    wud u plz stop fabricatin stuff i will never be able to have!
      couple of ostrich egg, egg cups should do for the ends
      My 4x4
      My choice
      Back off
        I think you should invest in a set of axle stands. I don't think balancing 2 ton of Surf on a plastic milk crate is a very good idea.
        BTW, how much was the metal tubing, and what sort of thickness is it?
        Paul </Slugsie>
        Immortal.so far!
          It looks like those brackets effectively bolt the body to the chassis - not a good idea
          Roger
            if you know of some in s/s please let me know,
              wot wot!!! there should'be any major movement between em should there?
              i painted all ove the lift spacers (as you can see) and aint notice any paint crack that ya'd get with movement, if this is a big nono tell me now before i go to far with it,
              i guess i could bolt the t peice instad of welding it? that would give it a bit of leeway in case of movement,
                It was about £88 from metalsdirect, for 3 meters (2x 1.5 mt actually) and its
                1.5mm wall, they do do a 2.5 wall (unpolished) about the same price.
                  B & Q do end caps for their breakfast bar supports, not sure of diam but might help you out
                  Tony
                  www.puppywalker.co.uk
                    Tony
                    had a look but they dont go up to 3" cheer's tho
                      Off to the motorway services with you and pinch some of their stainless teapots!!! (alternatively try Millets for a stainless cup.)
                      it's in me shed, mate.
                        Been looking at allsorts for a few weeks now mate, there's some nice bits on city bus bus stops but i aint got the front to remove em, i can just see the evening new's headlines
                          I think your referring to the fact that the body mounts are rubber and Popeys doesn't have this articulation built into his design.....mmm might be worth just body mounting them if you can..
                          Having said that, if you do it this way and have no problems then just leave it.
                          nice job.
                          Alan
                            They do have a WOW factor though
                              They had a god damit motha f###er factor when i grab'd hold of a hot bit,
