HELP!! red light!!
  • #16
    Originally posted by sarahMedz
    how do i do that?
    http://www.toyotasurf.asn.au/techsite/efifaultcodes.htm
    www.daemon4x4.org
    • #17
      i'm in Liverpool. what am i going to do!!! if my car breaks so will my heart!!! i love my car!!
      A word with Stevo then (Stockport) might sort your problems.
      I'm from Liverpool, though now in Worcester.
      <edit> dont rule out the head if the gasket was replaced without a thorough check of the head.
      • #18
        wow!!! you may aswel as wrote in spanish to me!!
        thanks for the info tho. ive printed it out and will have a read later. i'm not losing coolant either, i'm totally baffled by it!! nothing has changed, it feels and sounds exactly the same. so does that red light mean there could be anything wrong with the engine/electrics? this is really bad isnt it?
        • #19
          stockport, hey if ur from Liverpool did you ever go to the Leisure Lakes in Southport?
          • #20
            Nope. Haven't lived there for 20 odd years, but get up every 3 weeks or so to visit the folks.
            • #21
              if your def not losing coolant your turbo is going,that will bring the light on!
              • #22
                wel thank you for all of your help fellow scouser! i'm from Aintree and have only been in Liverpool for 21 years (all my life!) what would you recomend about the red light situation? i hope i can sort it out!!
                • #23
                  does that mean its a gonner?
                  • #24
                    no not a goner atall,get a turbo from breakers 50-100 ish,u will know if turbo is going,will use a bit of oil
                    • #25
                      i am losing oil aswel!! thort i cracked sumthing on the track tho, coz it started losing oil a while before the light came on.
                      • #26
                        the turbo on the surfs are oil cooled aren't they and the main thing that will go is the bearing if there is no oil pressure.This is what happened to my 3l at xmas and it sounded like a tin of nails
                        • #27
                          any idea where the oil is coming out from??
                          • #28
                            mine sounds normal and feels normal. am not sure, its at the front to the left, about a foot away from the tyer, could b coming from anywer tho, its nothin major, only losing a tiny bit.
                            • #29
                              That could be a front crank oil seal........is it on the inside of the bash plate
                              Would recomend a trip to stevo considering your location
                              www.daemon4x4.org
                              • #30
                                Understandably, there's a lot of guessing going on here. My recommendation is for you to get it over to a garage that knows Surfs, such as Stevo. A member here (Hilux Bob, or is he just 'Bob' now...) is near to you. Might be worth asking him to take a quick look to put your mind at rest.
