White Spirit In Veg Oil! Tried and Tested.
  • #16
    Would you be able to use white spirits instead of turpentine is it one and the same?
    www.brydenenterprises.co.uk www.kirstyskids.org
    • #17
      all the same stuff apart from the price.i paid £3.18 for a 4l container of white spirit
      • #18
        I bet CHIPS taste Discusting
        • #19
          i have mixed up 2 x 15l drums of ktc and that is now in the truck.I'll see how it runs over the next few days now and let you know.
          • #20
            Stormforce has had a go, are you gonna try it mudsurfer?
            Without Surf And Unhappy
            • #21
              The tuck started ok this morning and took it out for a good run and it seems to sound a bit quieter than it was.So at the moment it's still early but if it stays as it is i will be happy
              • #22
                I just poured a full 750 ml bottle into a full tank of wvo/svo/derv mix . I'LL REPORT BACK WITH MY FINDINGS
                • #23
                  Try to mix before putting it in, cos you dont want it to settle at bottom, giving you a very luimpy drive. Once mixed it stays so, and only mix it wiv veg oil as the diesel is lean enough, look forward to your findings buddy
                  • #24
                    I may give this a go on the Wales run, as my fuel pump has a leak on it, although if veg oil keeps going up( now 66p/litre), it'll be cheaper to run on derv.
                    Rob
                    Still working for the man!
                    • #25
                      mine is running fine if not better now than it did before mixing white spirit with the veg
                      • #26
                        as a veg user, i mix mine in the fuel tank, could i premix a 15lts veg with some white spirit and then add to my fuel tank with the derv , or have you got to have the two tank system????
                        • #27
                          just mix the w/spirit with the veg and give a bloomin good shake for a few mins just to make sure its well mixed and pour in the tank
                          • #28
                            I'll have to try it then, comeing back from ports today she had no power at all, seem'd ok going, the ba$tard let me down as i pulled out onto the busy eastern rd, had the pedal down on the floor and it just crawled up to speed,
                            dammed embarrasing when someone flashes ya out, it needs a can of Wynn's
                            "come on for christ's sake" spray'd down it,
                            • #29
                              Check your vaccume tubes are still connected and not split, as this will result in no turbo boost.
                              Rob
                              • #30
                                wont it mix in the tank with all the fuel sloshing around ??
