Originally posted by internetsurfer
White Spirit In Veg Oil! Tried and Tested.
would you not get a better mix by pouring in the white spirit BEFORE the Veg Oil ? surely 30 + Litres of Veg descending on it must have a mixing effect ?Originally posted by The Lang-Shankit ScunnerYes to a degree, but i like to be sure, if you pour it in and then leave the truck static it may be more of an issueLook out Eastbourne, the Pandas are coming !
Yes it would do, but I like to see it first hand before it goes in, by all means go for it in any way you prefer, im just the cautious type, especially when recommending others to do stuff. Have you tried it yet?Originally posted by UDTrevwould you not get a better mix by pouring in the white spirit BEFORE the Veg Oil ? surely 30 + Litres of Veg descending on it must have a mixing effect ?Without Surf And Unhappy
Under 5% is classed as an additive and doesnt constitute a fuel. Correct me if im wrong, and if illegal, topgear would be unable to televise it.Last edited by The Lang-Shankit Scunner; 9 October 2007, 21:38.Without Surf And Unhappy
Glad your gettin good results so far buddy, myself and stormforce are benefitting too, keep us all postedOriginally posted by internetsurferdrained the tank next day , fuel appeared to have mixed well with turps. startup seems to have lost that annoying tappet like rattle . other than that it seems fine , a bit better economy i think .
Nope just less side effects than too much oil. I am now currently on 750ml per 10 litres of oil. Remember thats with diesel, you wont get away without diesel in there too. I know stormy is doing 50/50 diesel - veg/ws mix. work it up from there until you get the lumpy's againOriginally posted by fireflyok guys im going for it got the container got the spirit got the oil, how is it going with you guys using it already no side affects?????Without Surf And Unhappy
mine is running fine with the mix.i can't give mpg as i have got 33's on and i won't have a correct mpg readingOriginally posted by fireflyok guys im going for it got the container got the spirit got the oil, how is it going with you guys using it already no side affects?????https://www.facebook.com/groups/henpals/
It has been discussed over at Biodiesel. infopop if someone it interested in more reading
http://biodiesel.infopop.cc/eve/foru...312#9751013312
http://biodiesel.infopop.cc/eve/foru...212#4321000212
Just an update on the 50/50 mix i tried.The truck certainly started and ran better.
Just to test out straight veg oil again i put in 20l and i could tell the difference almost straight away.There was a bit more smoke on start up and lumpier on tick over so i will be definately be running with the white spirit mixed in in futurehttps://www.facebook.com/groups/henpals/
