Handling Change with body lift?????
  • #31
    Originally posted by Veggie Surfer
    So does Vince do kits aswell as jotto? Just finkin of a quick turn around you see.
    Not BODY lift kits as far as I know...
    • #32
      not the bodylifts he don't its only Jotto you can get that from
      • #33
        or tony N.and thats propably why i didnt mess with the brake lines as i fitted goodridge extended hoses on mine to.
        www.overfab.uk
        • #34
          they were the same as mine but what was that spacer you put on the brakeline to raise it off of the axel
          • #35
            ummmmm,ummmm,ummm.i cant $$$$$$ remember.did we fit bushys drop kit.if so thats where the spacer came from in the first place then we fitted the extended goodridge hoses,didnt we.?????? and i must of left the spacer in place.sorry that all should of been (didnt I.)
            www.overfab.uk
            • #36
              I think that spacer basically lifts the brake line off the axle so the amount of 'slack' in the line remains the same as standard.
              • #37
                ummmmm,ummmm,ummm.i cant $$$$$$ remember.did we fit bushys drop kit.if so thats where the spacer came from in the first place then we fitted the extended goodridge hoses,didnt we.?????? and i must of left the spacer in place.sorry that all should of been didnt I.
                yep thats right ,you done the rear brake line and i managed to get the front 2 done about 7 months later but yea that spacer was part of the bushy special
                • #38
                  axel
                  tut.!!.AXLE
                  www.overfab.uk
                  • #39
                    tut.!!.AXLE
                    yea and that cause i got that aswell
                    • #40
                      So do i need to do anything with the front brake pipes, or do they have enough flex in em?
                      Without Surf And Unhappy
                      • #41
                        what i cant figure out is how andy can get away with not fitting extended hoses and yet he has the lc coils fitted too.i swear on stein i would of ripped the brake hose off the minute i went offroad with it.as it was very tight.
                        www.overfab.uk
                        • #42
                          the goodridge hoses come as a set of three two for the front and one on the rear.
                          www.overfab.uk
                          • #43
                            Cos he drives like a girl......
                            (lights blue touch paper and retreats to safe distance...)
                            • #44
                              If you get the extended braided brake lines then the roughtrax item no.is LK003
                              but if your only having a body lift i think you wont need the brake lines
                              • #45
                                OK cheers, I have had the rear suspension raised by an inch or 2 though, would this make a difference? Its just the uprated standard milners springs, with coil assisters that make another inch of height.
