I was wondering if a 2" body lift would affect the handling on my truck at all? It cant help it look any better because its burgundy and that is insurpassable
Handling Change with body lift?????
Quite so!Originally posted by Veggie SurferIt cant help it look any better because its burgundy and that is insurpassable
You'll want to watch out for the drop bracket - you may find you'll snap the bottom of it off - like I did, and you will wallow around bends when that happens -
You will notice a difference, and you'll approach bends a lot more slowly to start with, but I had a 1.5" body lift and 4" suspension lift at the same time.....oh yeah, and LC springs fitted...Too old to care, young enough to remember
it wont make alot of differance to handling but you may just get a little extra body roll but not alot i wouldn't think.i got a 5-6" lift with no arbs and i get a little extra body roll with that but i quite like like thatOriginally posted by Veggie SurferI was wondering if a 2" body lift would affect the handling on my truck at all? It cant help it look any better because its burgundy and that is insurpassablehttps://www.facebook.com/groups/henpals/
the bit hanging down from the chassis where the panhard rod bolts to.and it will effect your handling coz of the greater c of g.but like richard said it shouldnt be to much just adjust your driving technique to account for the lift.Originally posted by Veggie SurferWhats the drop bracket then? So i can look out for not snapping off said bottom of it.
Already put in 2" spring spacers on back just to give it a slightly higher back end.www.overfab.uk
and make sure you take a good line offroad.......Originally posted by Veggie SurferOk never mind, im not sure i follow the description. Bottom line is be carefull not to brake anythin and drive slow around corners. Gotcha thanks everyoneToo old to care, young enough to remember
Yeah - you coming down for that??Originally posted by Veggie SurferThanks mate, will do that i hear srtts is a good start for a novice off roader.
Let me know - I'm trying to sort out a convoyToo old to care, young enough to remember
Let me know then, if you have a CB I'll be on Ch 39 - if not, you'll need to let me know your cell phone number so we can arrange the meeting place on the way down...Originally posted by Veggie SurferMaybe, 625 miles for me, thats alot of veg oil, i have 2 tanks thoughToo old to care, young enough to remember
Carl,if you fancy somethin closer to home theres Drumclog at the end of September,great event with somethin for eveyone
2 tanks...show off.
www.scottishmudclub.com for scottish events
Oh yes snort snort, i have the twin tank valved up heated automatic switch controlled quick purging veg kit, which aloows me to run ma truck on anything liquid based.Originally posted by smiffyCarl,if you fancy somethin closer to home theres Drumclog at the end of September,great event with somethin for eveyone
2 tanks...show off.
Will let you know mudsurfer, ma wife is up the duff and may not get such libertys
Drumclog sounds a good idea aswell(more realistic) There any smooth and sticky there?Without Surf And Unhappy
Ha! Tanks are obsolete since this thing! No matter if you have 2 or 200!Originally posted by smiffyCarl,if you fancy somethin closer to home theres Drumclog at the end of September,great event with somethin for eveyone
2 tanks...show off.
