carl i used to specialise in them mate and regarding the diferance you may be terified at first truth is most lads dont like to admit it but the biger the lift the wors the drive gets` i have had people say to me please could you make it standerd again but a 2" isnt anything to be botherd about ` also having the right wheels and tyres make a big diferance , one of my last ones i drove was a stagaring 12" it was like driving blackpool tower with wheels on lol , people used to say where is the rest of the show ' i just got me self a nice 3ltr big thing today` with big wheels on it looks the dogs whatsits trouble is the biger you make it ` the more your hated by the save the envioment $$$$$$$s
Handling Change with body lift?????
RE: 2" Body Lift
It just seems like alot of work, with the risk that it can go wrong. I know i should undo the rad before i start, and the steering rack bolts, but should i undo anything else? Im aware that i should do a side ata time, allowing bolts to hold one side while i jack the other.
Am I unduly worried? Only it seems the cheapest way to get some height.
Oh and shes sitting on 31x10.5 R15Last edited by The Lang-Shankit Scunner; 22 August 2007, 20:43.Without Surf And Unhappy
You ARE unduly worried. It's dead easy. Take it slow and keep an eye on anything that might get stretched while you're jacking.Originally posted by Veggie Surfer
Oh and shes sitting on 31x10.5 R15Cutting steps in the roof of the world
there no need to worry about doing the lift.You will need to slacken the fuel filler pipe under the rear wheel arch also and do the drivers side first then the passenger side.You will need a couple of jacks tho to lift the body and only lift the body enough to get the spacers inOriginally posted by Veggie SurferIt just seems like alot of work, with the risk that it can go wrong. I know i should undo the rad before i start, and the steering rack bolts, but should i undo anything else? Im aware that i should do a side ata time, allowing bolts to hold one side while i jack the other.
Oh and shes sitting on 31x10.5 R15https://www.facebook.com/groups/henpals/
Have a chat with Jotto on here but you may have to wait a short while as he has only just moved houseOriginally posted by Veggie SurferThanks mate, know of anyone who can supply kit with drop brackets for rad and raise brackets for bumper?
Eager to get it up me!!!!https://www.facebook.com/groups/henpals/
i wouldnt worry its a easy job to do.undo the ten body bolts,undo the fuel filler hose clips,undo the steering column bolts and steering column grommet bolts,cut out a little bit of steel around the h/l shifter on the front and cut out a bit from the steering column grommet,fit the rad drop brackets and the bumper drop brackets, fit the spacers and bolts.i dont think ive left anything out.Originally posted by Veggie SurferRE: 2" Body Lift
Oh and shes sitting on 31x10.5 R15www.overfab.uk
Probably bears mentioning that not all of those things neccessarily need to be done with all Surfs.Originally posted by surfensteini wouldnt worry its a easy job to do.undo the ten body bolts,undo the fuel filler hose clips,undo the steering column bolts and steering column grommet bolts,cut out a little bit of steel around the h/l shifter on the front and cut out a bit from the steering column grommet,fit the rad drop brackets and the bumper drop brackets, fit the spacers and bolts.i dont think ive left anything out.
Didn't need to loosen the filler hose, or cut round the hi/lo shifter on mine. I actually forgot to undo the grommet, and now it's worn away
also i think on the body lift you have to undo the brakeline atattched to the rear axel so you got some play in the brake line and it don't get stretchedOriginally posted by surfensteini wouldnt worry its a easy job to do.undo the ten body bolts,undo the fuel filler hose clips,undo the steering column bolts and steering column grommet bolts,cut out a little bit of steel around the h/l shifter on the front and cut out a bit from the steering column grommet,fit the rad drop brackets and the bumper drop brackets, fit the spacers and bolts.i dont think ive left anything out.https://www.facebook.com/groups/henpals/
If you have a hacksaw and a drill and can lay your hands on a bit of steel sheet, you can make those bits yourself. Nowt to them.Originally posted by Veggie SurferThanks mate, know of anyone who can supply kit with drop brackets for rad and raise brackets for bumper?
Eager to get it up me!!!!Cutting steps in the roof of the world
Or just fit shiney new steel Goodridge ones...Cheers Mark!Originally posted by stormforcealso i think on the body lift you have to undo the brakeline atattched to the rear axel so you got some play in the brake line and it don't get stretched
Something else that must be different from truck to truck. I didn't need to do that and I've still got plenty of slack.Originally posted by stormforcealso i think on the body lift you have to undo the brakeline atattched to the rear axel so you got some play in the brake line and it don't get stretchedCutting steps in the roof of the world
thats the extended ones like i got.I know what it was now in the kit from bushy and that was a spacer for the brake lineto raise it from the axel about 1.5".its where the brake line T's off to both sidesOriginally posted by MudSurferOr just fit shiney new steel Goodridge ones...Cheers Mark!
