Fully synthetic oil
  • Fully synthetic oil
    Hi, Anyone using fully synthetic oil in your truck's engine? As most of u recommends Semi synthetic engine oil. my Q: why not fully synthetic?
    Truckin' Time
    oil pressure !! waste of money if you change oil regular
      I use Semi Synthetic.
        oil pressure?
        Truckin' Time
          I've heard folk say that a fully synthetic will free up a lot of crud in the engine if its had only mineral before.
          Dave
            Fully synthetic tends to be thinner. Also the Surf wasn't designed to run on it.
            Roger
              means after 1-2 oil changes i get a cleaner engine free from carbon deposits and no more crud thereafter
              Truckin' Time
                I always use the same grade and type of oil that was available when vehicle made . Modern vehicle tolerances are tighter then 10 years or so , so the more modern oils will be to thin as already posted . I run Tam's '68 Herald and my Runner on good old 20/50 cheapo oil £3 per gallon. Good oil pressure and lasts well .
                  So Final word for all to follow:
                  1. Surfs 1st - 3rd gens are not designed for fully synth
                  2. max go for Semi synth
                  3. Best use mineral cheapo
                  Am I right?
                  Truckin' Time
                    Am I right?
                    I only use cheapo oil as my choice . You use wot you want , its your choice . I dont want to be resposible for your choice . As long as the oil meets SAE spec in user manual it is suitable for its purpuse .
                      Crud in the right place is no bad thing. But free it all and who knows where it'll end up before the next oil change.
                      Dave
                        Would you use mineral in a full synth engine???? NO!
                        So why use full synth in a mineral engine. SHEESH.
                        Cheap and change regular as per Toyo instructions.
                          That's not a balanced question, though. It can work one way, but not the other. A question like that needs two equally balanced alternatives or opposites.
                            Oil!!! Wassat then? Do I need it then?
                            Cheers, Nick
                            "The force will be with you, always!"
                              i used castrol magnatec semi synth 5/30 last 6 months,thought it was ok until i just put in magnatec 10/40 semisynth...now i realise why my engine was noisier than a bag full of cats....goes to show the more expense/quality of the oil dont always help!!like vagrant said 16 years ago 5/30 or fully synthetic oil was like finding a virgin in essex high st!!
