I tried fully synthetic and it did seem to clean out some of the crud, After a long discussion with my local supplier I have gone for semi-synthetic and she seems to run quieter and smoother on it. It is thicker ( and a lot cheaper).
10/40 or 15/40 semi-synth. Anything more expensive than that is a waste of money.
Must agree with AuldNick slightly on this one. (It will be the first and last time I hope).
Running a semi-synth in an engine that's designed for full-synth would probably kill it.
With a semi or mineral oil, some of the 'sludge' in the oil is due to constituents of the oil itself.
Shifting it can sometimes be detrimental, rather than beneficial.
The engines died because of a sludge buildup, which was remedied simply by using a fully synth 0/30, I believe? The oil they had recommended initially killed the engines.
older engines may work on any oil, but be prepared for sudden leaks if any of the gaskets or such are of unknown quality. Place any other oil in a newer engine than the one specified, and be prepared for the fact that it may cough and die. The tolerances are just way too tight on more recent engines to risk deviating from the manufacturers specified oil types.
