a bit of help needed
  • #16
    yer mate bonded on with tiger seal ( auto sealant ) like the stuff screens are fitted with and it has no movment at all.
    if you need some let me know and ill send you some .
    try testing yours on the battery and see if the loom heats up if not then i got a duffer and will rip the loom out and fit my own.
    john...
    i bust things ,, it a skill i have ,,( need help?)
    • #17
      john...
      If you could send me some mate that would be absolutly fantastic! How much ££ would you want?
      i'll check the loom tomorrow for you mate and let you know if it heats up!
      Should there any heat at all? or just none whatsoever? Electrics aint my forte in case you didnt guess!
      • #18
        If the cable is heating up, it's either due to dodgy connections or the cable not being beefy enough for the application.
        • #19
          hi matt you could be spot on as i have redone two connections before fitting as they felt loose . i think i will check the rest..
          rod pm me your addy and i will send a tube out foc ..
          john...
          • #20
            Best thing to do would be to get rid of the bullet connectors completely and use barrel crimps or solder the wires together.
            • #21
              john...
              Pm sent! Thanks mate!
              • #22
                got it working now i think.
                o and i removed the graphics as well so it all blacknow
                rod will send that out asap for you ...
                john
                • #23
                  hmnn they do look tasty!!!!
                  Cant wait to have mine wired up!! AND then randomly drive into a field at night to try them out an see how bright they are
                  • #24
                    done two wheels in honda type r graphit wheel , will do the others this week.
                    look good but i may redo them darker as dark is good and black is better
                    • #25
                      rod if you look at them you will see that the outer two point out a bit so will light it up like blackpool..
                      john
