1 1/2 inch body lift
    Originally posted by ohsupremebeing
    I think I can live with doing that thanks
    Chris you will have to lower the rad in yours as you've got a 2.4. If you dont then the rad will be higher than the rad cap and could cause air locks
      That sounds harder then lowering the rad surround but if it has to be done then it has to be done
      so the list to mod for a 1 1/2 inch body list is
      lower rad
      lift bumers
      drill holes in bulkhead plate 2mm bigger to allow it to be lowered lower for steering column
      and start lift on drivers side
      anything else
        lower rad
        lift bumers
        anything else
        undo the fuel filler pipe in the rear wheal arch before lifting but remember to do it back up again after.(only need to slacken it not take it off)
        unclip the brakelines from the body underneath near to where they go to the axel so you dont damage them
          lower rad
          lift bumers
          anything else
          Lift bumers??!!
          What ever floats yer boat mate!
            Lift bumers??!!
            Elevator Chutney Ferrets?
              Gay midgets?
                lower rad
                lift bumpers
                adjustment to steering column
                undo fuel filler pipe
                unclipe brakelines from body at rear axel
                anything else
                you lot dont miss anything do u lol
                  lower rad
                  lift bumpers
                  anything else
                  not sure if you need to do it but you may need to unclip the handbrake cable from the chasis before it goes to the wheels
                  • #24
                    lower rad
                    lift bumpers
                    anything else
                    YEAH my phone is out of order
                    Live Life To The Full
                    • #25
                      whats that got to do with my lift $$$$ off he he he
                      • #26
                        lower rad
                        lift bumpers
                        anything else
                        Either Apache's truck was once lifted and then lowered before he bought it, or it's one of the easiest trucks to 'lift', 'cos the only two (extra) things we done when fitting a 2" body lift was to raise the front bumper and lower the rad!!!
                        • #27
                          Nope.
                          • #28
                            Well now my steering column grommet has worn away anyway...
                            Must make a new one someday.
                            • #29
                              But isn't your steering column at max. adjustment anyway?
                              • #30
                                There probably wasn't a lot to play with, certainly not on the splines in the engine bay...
