Originally posted by ohsupremebeing
1 1/2 inch body lift
Originally posted by stormforce1067Chris you will have to lower the rad in yours as you've got a 2.4. If you dont then the rad will be higher than the rad cap and could cause air locks
That sounds harder then lowering the rad surround but if it has to be done then it has to be done
so the list to mod for a 1 1/2 inch body list is
lower rad
lift bumers
drill holes in bulkhead plate 2mm bigger to allow it to be lowered lower for steering column
and start lift on drivers side
anything elsexxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
undo the fuel filler pipe in the rear wheal arch before lifting but remember to do it back up again after.(only need to slacken it not take it off)Originally posted by ohsupremebeingThat sounds harder then lowering the rad surround but if it has to be done then it has to be done
lower rad
lift bumers
anything else
unclip the brakelines from the body underneath near to where they go to the axel so you dont damage themhttps://www.facebook.com/groups/henpals/
lower rad
lift bumers
anything else
Lift bumers??!!
What ever floats yer boat mate!
lower rad
lift bumpers
adjustment to steering column
undo fuel filler pipe
unclipe brakelines from body at rear axel
anything else
you lot dont miss anything do u lolLast edited by ohsupremebeing; 14 April 2007, 01:23.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
not sure if you need to do it but you may need to unclip the handbrake cable from the chasis before it goes to the wheelsOriginally posted by ohsupremebeingso the list to mod for a 1 1/2 inch body list is
lower rad
lift bumpers
anything else
you lot dont miss anything do u lolhttps://www.facebook.com/groups/henpals/
YEAH my phone is out of orderOriginally posted by ohsupremebeingso the list to mod for a 1 1/2 inch body list is
lower rad
lift bumpers
anything else
you lot dont miss anything do u lolLive Life To The Full
lower rad
lift bumpers
anything else
Either Apache's truck was once lifted and then lowered before he bought it, or it's one of the easiest trucks to 'lift', 'cos the only two (extra) things we done when fitting a 2" body lift was to raise the front bumper and lower the rad!!!
Well now my steering column grommet has worn away anyway...Originally posted by BUSHWHACKEREither Apache's truck was once lifted and then lowered before he bought it, or it's one of the easiest trucks to 'lift', 'cos the only two (extra) things we done when fitting a 2" body lift was to raise the front bumper and lower the rad!!!
Must make a new one someday.Cutting steps in the roof of the world
