tweaking
  • tweaking
    can anybody give me any advice on whether its worth adjusting the little screw under the thimble(technical term)on the injection pump ,read a couple of threads and some folk recon it gives you a bit more power and the truck runs better is this true?
    if it aint broke...
    unless you know exactly what you're doing i wouldn't adjust anything that i couldn't put back to original setting if i were to encounter a problem. but it's up to you, if you feel confident you know what you're doing, go for it.
      Some folk on the forum have done this tweek with varying degrees of sucsess, but no terminal failures yet.
      Rob
      Still working for the man!
        Yes it is
          Tweak it, deffo worth the ten mins effort to take you very close to 3ltr range and still better MPH.
            go for spaceing out the turbo actuator while you are at it
              You mean the wastegate John!
                oh is that what it was i stuck the washer behind then, as usual silly ol me
                  What is this mod please, is it worth doing?
                    Without doubt this is worth doing. I had a running problem that felt like mild fuel starvation while cruising between 30-40 mph. Since turning the adjuster about seven clicks clockwise this has gone and performance is better. I drove a 3ltr 3rd gen last week and this had no more umph than mine so definately think it worthwhile.
                      I done mine over a year ago now with no problems.
                      It increases the boost pressure of the turbo, or rather it lets the turbo spool up higher before the waste gate opens.
                      It's advisable to fit a boost gauge, but I didn't. I think the spring in the wastegate actuator weakens over time, and packing it out with the washers brings the boost pressure back to where it was when the truck was new.
                      http://www.toyotasurf.asn.au/techsite/cheapboost.htm
                        Vince, how many washers did you pack it out by? I did 3x3mm and noticed an immediate improvement. Did you do the fuel pump mod as well?
                        Simon
                          Simon
                          The same amount of washers as you and a quarter turn clockwise on the screw.
                            I'll try this. Thanks for your help Vince.
                              Simon
                              Do you mean 3 washers total, I assume that you don't mean 3x3 i.e. a spacing of 9 mm in all. Sorry if this seems an odd question but have not taken cover off so don't know what is inside.
