can anybody give me any advice on whether its worth adjusting the little screw under the thimble(technical term)on the injection pump ,read a couple of threads and some folk recon it gives you a bit more power and the truck runs better is this true?
tweaking
if it aint broke...
unless you know exactly what you're doing i wouldn't adjust anything that i couldn't put back to original setting if i were to encounter a problem. but it's up to you, if you feel confident you know what you're doing, go for it.i swear, it was like that when i got here...
Originally posted by brian88883can anybody give me any advice on whether its worth adjusting the little screw under the thimble(technical term)on the injection pump ,read a couple of threads and some folk recon it gives you a bit more power and the truck runs better is this true?Too young to die and too old to give a toss
Originally posted by beaufighterWhat is this mod please, is it worth doing?
I done mine over a year ago now with no problems.
It increases the boost pressure of the turbo, or rather it lets the turbo spool up higher before the waste gate opens.
It's advisable to fit a boost gauge, but I didn't. I think the spring in the wastegate actuator weakens over time, and packing it out with the washers brings the boost pressure back to where it was when the truck was new.
http://www.toyotasurf.asn.au/techsite/cheapboost.htm
Originally posted by BUSHWHACKERI done mine over a year ago now with no problems.
Originally posted by The HornetVince, how many washers did you pack it out by? I did 3x3mm and noticed an immediate improvement. Did you do the fuel pump mod as well?
Simon
