'Clunk' from rear
  • 'Clunk' from rear
    Firstly, appologies for posting this question in the general section but as I don't know where the 'Clunk' comes from, I wouldn't know which technical forum to put it in.
    Anyway, as you can probably guess, I'm suffering with a strange 'Clunk' from the Surf. This 'Clunk' occurs only on making a R/H turn, although not every time. It's more noticable on 90 degree turns or mini roundabouts but will also happen on gradual right handers. Immediate thoughts were a bush on any of the usual suspects but all appears well at least at first glance. Pulling/twisting doesn't indicate anything amiss either. Bouncing the suspention whilst static doesn't induse the 'Clunk' nor does potholes or speedbumps irrispective of the speed.
    Slightly more worrying was that, prior to purchase, the former keeper had mentioned a sticking clutch plate in the LSD which had made a noise on R/H turns. He'd topped up the oil in the diff & the problem had, apparently, gone. I've now driven a couple of thousand miles since I got it & the 'Clunk' is now more frequent & noticeable. I must admit, I've never heard of this kind of problem with a LSD but I'm no expert. On occasions, the noise is quite loud &, to me, too loud to be comming from the diff.
    Any advice would be much appreciated.
    Ta.
    First guess would be a broken anti roll bar bracket.
    It just does, OK?
      Second guess would be to jack the back up and see if their is any play in
      the wheel. Could be something as minor as a loose or incorrect wheel nut.
        third guess... ....i'll just go with what they 2 said
          4th guess,check rear shocks and springs(may or maynot be broken)
          www.overfab.uk
            1st guess would be take note of what the previous owner stated. If you have LSD could be problems
            Gaz
              Worthwhile checking the more minor possibilities first, though.
                Check you rad cap!
                  Could be worth checking shockers, I suppose. Also, I've only looked at the R/H side as it's on turning right that the noise happens, perhaps I should check the left side too.
                    Check you rad cap!
                      BTW, whats everyone's recommended oil for LSD's?
                        LSD oil
                        Originally posted by Sticky in general mech section
                        LSD rear diffs just use specific LSD gear oil
                          Yes, OK! I should have asked which brand of LSD oil people prefer.
                            Vince's fantastic sense of humour
                            It's always the rad cap.....
                              Ahh! I see.
                              Must be because I'm a dour Scot that that one went right over my head. Then again, I could just be stupid
