any ideas how to get a steel put up...
  • any ideas how to get a steel put up...
    ....without a crane. (too expensive!)
    we have 2 to put up, the biggest one is about 5m long.
    Tim
    Do you mean a steel lintel?
    I put a 8" X 5.5" X 5 metre one up on my own, just gradually lift one end up at a time on ever increasing piles of blocks until you get it up to the required height. How high do you need to lift yours?
      have you thought about hiring some hoisting equipment from speedy hire etc ??
        Do they hire out sky hooks too?
          your showing your age with them jokes vince
            High lift jacks and lots of blocks of wood.
              Can you still buy sparks for the grinder? and what about striped paint?
                You should use a couple of chain hoists if you've got a couple of fixing points and some slings. A couple of frottoes would be perfect if you could get hold of them, or maybe a big floor crane.
                If it's just a Catnic you should be able to lift it between two of you, but I didn't tell you to do that.....
                  get a genie lift they cost about £60 a day from tool hire shops.
                  colin
                    colin
                    You can get them in bottles too!
                    just rub the sides and they pop out in a puff of pink smoke, then you tell them to put the steel up and it's done in a blink of an eye.
                      when i ever had problem like that a few mates and a crate of beer in background works everytime
                      Enjoying Life after Cancer
                      Pops
                        See your getting plenty of good advice, load of mate's and a few beers as pops says is about the cheapest way, Joker's not too far from you, he'll do it
                          hehehe - cheers for the advice guys, its Dads job I think he has people to ask...
                          the steel needs to go up to gutter height!
                          Tim
                            could you not wangle it up the stairs??
                            or stand it upright and secure the top end, then using a pulley arrangment, lift / swing the bottom end up.
                              Sounds like the ideal time to justify buying a winch for the Surf, then using a block and tackle you could winch it up.
                              Paul </Slugsie>
                              Immortal.so far!
