....without a crane. (too expensive!)
we have 2 to put up, the biggest one is about 5m long.
Do you mean a steel lintel?
I put a 8" X 5.5" X 5 metre one up on my own, just gradually lift one end up at a time on ever increasing piles of blocks until you get it up to the required height. How high do you need to lift yours?
You should use a couple of chain hoists if you've got a couple of fixing points and some slings. A couple of frottoes would be perfect if you could get hold of them, or maybe a big floor crane.
If it's just a Catnic you should be able to lift it between two of you, but I didn't tell you to do that.....
See your getting plenty of good advice, load of mate's and a few beers as pops says is about the cheapest way, Joker's not too far from you, he'll do it
