bonnet scoops are largely cosmetic when forward facing. they tend to fall with in the boundary layer alot of the time so dont actually scoop anything in at all. especially when the under bonnet pressure is equalised by the air coming in through the front. they look $$$$in sweet though and ill be fitting one as soon as i can afford it on the list of things.
top mount intercooler heatsoak happens worst when stood still, in traffic for example, the still air rises and warms the cooler up and then when you come to pull away its not working at all. but to front mount it means longer pipe runs and more lag, plus im guessing the hilux doesnt run particularly high boost pressures so there isnt going to be as much heat buildup in the cooler. so its less of an issue
i think a bonnet scoop will actually work better if it faces backwards.
 and feel that it would make a pleasent boost to my motors performance.
 Unless some one has a spare 3rd Gen KZN 185 Inter-Cooler kit and bonet lying around
