Auto gearbox and clutch wear
  • Auto gearbox and clutch wear
    I know if you use your clutch to stop car from rolling back (i.e., keep clutch at biting point) in traffic/slope, you will wear it out prematurely, but what if you use the brake, is the clutch still biting? Or would I be better off selecting N everytime I stop at traffic?
    Absolutely. Into neutral and handbrake on , especially if you know you're gonna be waiting for more than 30 seconds.
      An auto gearbox doesn't have a clutch (does it?)
      Laugh!!! I nearly bought my own beer.
      Paul
        nah... torque converter... have a look at http://auto.howstuffworks.com/torque-converter.htm
        will reveal all!!...
          There's still a clutch (plate) in an autobox(?). It only does away with the clutch pedal.
          If I remember right, an auto box uses valves and pressure of the lube to sense whether it needs changing
            no clutch
            the new rangerover autos have a different type cos it's an electronic box (i think).... regular clutch / gearbox but with computer control
              There are clutches in an autobox , but not the same as a manual car . I know as I have blown them apart in the past .
                Just checked with no1 son who is a mechanic - No clutch in an auto gearbox, as said above its a torque converter which works by spinning oil inside a chamber (but it's slightly more sophisticated than that).
                Paul
                  not like a conventional clutch though... they're sommet to do with locking the gears in... don't think they get much wear cos they're either "on" or "off"... but autos are a bit of a mystery!
                    I am a number 1 mechanic and I know my onions and this page agrees with me :
                    http://auto.howstuffworks.com/automa...nsmission5.htm
                      Clutches or no clutches (I'll not argue ) I don't think it actually does any harm to leave the car in gear when stationary, maybe just uses a bit more juice as the engine is still trying to drive the car foreward.
                      Paul
                        I would have thought the fluid temp will rise doing that.
                          The 'clutches' in an autobox are used to stop various parts of the epicyclic geartrain (bit like a series of complicated differential gears) revolving. Once a gear is engaged, the clutch does not wear as the appropriate part of the geartrain is then stationary. They are heavily engineered and run fully immersed in auto fluid and are designed to last a lifetime or more.
                          The equivalent component to the manual gearbox clutch is the torque convertor, which is a fluid coupling between the engine crank and the gearbox. It's a bit like stirring a cup of tea with a spoon. So you can stay all day with a gear selected and the brake on. Nothing will wear out - but you will be doing work in the torque convertor and work = energy = fuel. If you drop into N, you will save a small amount of fuel.
                          Kev
                            only stick mine in N occasionally or if im messing around freewheeling to r/b's etc.
                            Who said autos are no fun
                            Tim
                              Way to bang your drum!
