I know if you use your clutch to stop car from rolling back (i.e., keep clutch at biting point) in traffic/slope, you will wear it out prematurely, but what if you use the brake, is the clutch still biting? Or would I be better off selecting N everytime I stop at traffic?
Auto gearbox and clutch wear
An auto gearbox doesn't have a clutch (does it?)Originally posted by NewboyI know if you use your clutch to stop car from rolling back (i.e., keep clutch at biting point) in traffic/slope, you will wear it out prematurely, but what if you use the brake, is the clutch still biting? Or would I be better off selecting N everytime I stop at traffic?Laugh!!! I nearly bought my own beer.
Paul
nah... torque converter... have a look at http://auto.howstuffworks.com/torque-converter.htmOriginally posted by paulhAn auto gearbox doesn't have a clutch (does it?)
will reveal all!!...nee nar nee nar, i'm a fire engine!
There's still a clutch (plate) in an autobox(?). It only does away with the clutch pedal.Originally posted by paulhAn auto gearbox doesn't have a clutch (does it?)
If I remember right, an auto box uses valves and pressure of the lube to sense whether it needs changing
Originally posted by NewboyThere's still a clutch (plate) in an autobox(?). It only does away with the clutch pedal.
no clutch
the new rangerover autos have a different type cos it's an electronic box (i think).... regular clutch / gearbox but with computer controlnee nar nee nar, i'm a fire engine!
Just checked with no1 son who is a mechanic - No clutch in an auto gearbox, as said above its a torque converter which works by spinning oil inside a chamber (but it's slightly more sophisticated than that).Originally posted by NewboyThere's still a clutch (plate) in an autobox(?). It only does away with the clutch pedal.
If I remember right, an auto box uses valves and pressure of the lube to sense whether it needs changingLaugh!!! I nearly bought my own beer.
Paul
I am a number 1 mechanic and I know my onions and this page agrees with me :Originally posted by paulhJust checked with no1 son who is a mechanic - No clutch in an auto gearbox, as said above its a torque converter which works by spinning oil inside a chamber (but it's slightly more sophisticated than that).
http://auto.howstuffworks.com/automa...nsmission5.htm
Clutches or no clutches (I'll not argue ) I don't think it actually does any harm to leave the car in gear when stationary, maybe just uses a bit more juice as the engine is still trying to drive the car foreward.Laugh!!! I nearly bought my own beer.
Paul
The 'clutches' in an autobox are used to stop various parts of the epicyclic geartrain (bit like a series of complicated differential gears) revolving. Once a gear is engaged, the clutch does not wear as the appropriate part of the geartrain is then stationary. They are heavily engineered and run fully immersed in auto fluid and are designed to last a lifetime or more.
The equivalent component to the manual gearbox clutch is the torque convertor, which is a fluid coupling between the engine crank and the gearbox. It's a bit like stirring a cup of tea with a spoon. So you can stay all day with a gear selected and the brake on. Nothing will wear out - but you will be doing work in the torque convertor and work = energy = fuel. If you drop into N, you will save a small amount of fuel.
Kev
