Surf Towing & Caravan Things
  • salt it
    Originally posted by marky
    Good idea PHIL i'll give it a go
    another tip is to put bowls of ordinary salt in the van it draws moisture in a treat
    • Originally posted by snowy
      Just ask any slug
      It's only a hobby!
      • watch your insurance if you use winter wheels! it's been known for insurance co. to refuse payout because no wheel clamp can be fitted. GIVE THEM AN EXCUSE they will use it.
        • Hey Sparky in blackpool end of this month for 4 days at a site called Pipers height........ do you know it and is it any good. cheers Dave
          • Im off to take all my bedding out this weekend & get it ready for HIBERNATION
            • Didn't know you were just a fair weather caravanner Marky If you take the bedding out where are the mice going to sleep?. Am just trying to decide if I go to a Christmas rally or the New Year one.
              Visit all the Surfin Elkhounds at [url="http://www.malenibo.co.uk/"]www.malenibo.co.uk[/url]
              • They reckon that Monday could be the start of one of the coldest Winters for many a year. Make sure that all water tanks are drained, including the cassete toilet and flushing tank.
                It's only a hobby!
                • Originally posted by kitesurf_phil
                  Leave your taps open as well
                    Dont mind cold as long as it doesnt just rain and rain and rain for 6 months on end!!
                    Linda
                    www.4x4toys.co.uk
                    • Originally posted by Linda
                      Rain means lots of mud. Rain means nice deep fords to wash the mud off. Rain means I'll never get the welding on my Zook finished,so I can go out to play in the mud.
                      It's only a hobby!
                      • Caravans dont like MUD
                        • Legal issues of towing
                          Maximum sizes for towing
                          Towing vehicle under 3500kg GVW
                          Length (excluding the coupling and drawbar)
                          7.0 metres
                          Maximum width
                          2.3 metres
                          Towing vehicle over 3500kg GVW
                          12 metres if at least 4 wheels
                          Maximum width
                          2.55 metres
                          Length of towing vehicle & trailer combined
                          18 metres
                          Maximum overhang of load from rear of trailer
                          3.05 metres
                          Further information from: National Trailer and Towing Association (NTTA)
                          www.ntta.co.uk/law/law/
                          Maximum trailer sizes
                          Type 01: unbraked trailers - max. 750kg gross trailer weight or half the towing vehicle's kerb weight - whichever is less.
                          Type 02: trailers on overrun brakes - max. 3500kg gross trailer weight.
                          1982 regulations require that all trailers, including unbraked ones, must be clearly marked with their maximum gross weight in kg. This may be checked at any time by the police at a weighbridge. Since 1 January 1997, all unbraked trailer plates must show the year of manufacture.
                          Safe weight ratios
                          For stable and safe towing we would always recommend that you choose the smallest and lightest possible caravan suitable for your intended use. The less the laden weight of the caravan is in relation to the weight of the towing vehicle, the safer and more stable the outfit will be. The Caravan Club, for example, advises that you should aim for a towed load that is no more than 85% of the car's kerb weight for stability and safety. The CC advice is NEVER to tow above 100% of the car's kerbside weight.
                          N.B. The car manufacturer's specified maximum permissible towload is always the absolute towing limit regardless of any 85% or 100% weight ratio guideline. This is especially important in those cases where the manufacturer's figure is particularly low - in a few cases even below 85%.
                          Load distribution
                          Proper load distribution, in general, must be ensured too, with all heavy items in the caravan low down and directly over the axle wherever possible. Correct tyre pressures for car and caravan are absolutely vital.
                          Noseweight
                          It is a legal requirement that the noseweight should be 4% of the weight of the trailer or at least 25kg, whichever is the higher.. For safety you should aim for, but not exceed, the lower of the 2 figures specified for caravan and car respectively.
                          Passengers
                          It is illegal to carry passengers inside a caravan whilst on the road. It is permitted for pets to travel in the caravan, although this is not recommended safe practice.
                          Driving Licences
                          A full (not provisional) driving licence is required to tow a caravan. From 1 January 1997, new category B (generally held as 'normal' car entitlement) vehicles may be coupled with a trailer up to 750kg Maximum Authorised Mass allowing a combined weight of up to 4.25 tonnes MAM OR a trailer (for example a tourer) over 750kg MAM provided the MAM of the trailer does not exceed the unladen weight of the towing vehicle, and the combination does not exceed 3.5 tonnes MAM. This would mean that many drivers who possess only a category B on their licence would be able to tow a caravan provided it was not heavier than their car, and that car and caravan combined, does not weigh more than 3.5 tonnes.
                          New drivers of outfits over these limits must take a category B + E test.
                          Further information from: Driver and Vehicle Licencing Agency (DVLA)
                          www.dvla.gov.uk
                          Speed
                          Towed outfits may travel at up to 50 mph on single carriageway roads and up to 60 mph on dual carriageways and motorways. Towed outfits are not permitted in the outside lane of a three or more lane motorway unless other lanes are closed.
                          Brakes
                          A caravan with a maximum design laden weight of more than 750kg must be braked with an intertia (overrun) type braking system up to a maximum permissible laden weight of 3500kg.
                          Road lights
                          Caravans must have flashing indicators fitted at the back. A buzzer or other means of alerting the driver must be installed to highlight the failure of any of these indicators.
                          Caravans must have two rear lights conforming to certain size requirements and bearing the appropriate CE mark. Marker lights must be fitted 'as high as practicable' on the side or at the front and rear of caravans over 2.1m wide
                          • glossary of terms
                            GLOSSARY
                            GROSS WEIGHT
                            The total weight of the trailer (or towing vehicle) and load Gross Vehicle Weight (GVW) or Gross Weight Mass (GWM) The total weight of the towing vehicle and its load.
                            GROSS TRAIN WEIGHT
                            The maximum allowable combined weight (combined MAM) of the towing vehicle and trailer as set by the towing vehicle manufacturer.
                            KERBWEIGHT
                            The weight of the towing vehicle (without payload), including all fluids required for operation, 90% full tank, 68kg driver and 7kg luggage.
                            MAXIMUM GROSS WEIGHT
                            The maximum figure set by the manufacturer for the gross weight. This will normally be the technically permissible maximum based on the carrying capacity of the tyres, axles, coupling, suspension and chassis but may have been adjusted downwards for commercial reasons.
                            MAXIMUM AUTHORISED MASS
                            As above
                            MAXIMUM TOWING LIMIT
                            The most weight a car may tow (specified by the manufacturer).
                            MTPLM
                            The maximum weight of the caravan, as stated by the manufacturer (pre-1998 caravans: MGW, or Maximum Gross Weight).
                            NOSEWEIGHT
                            The maximum downward force your towball can bear, or your caravan exerts.
                            MASS IN RUNNING ORDER (MIRO)
                            The weight of the caravan equipped to the manufacturer's standard specification.
                            UNLADEN WEIGHT
                            The weight of the trailer (or towing vehicle) less removable optional equipment and load.
                            USER PAYLOAD
                            The user payload comprises all extra items not included in the manufacturer's standard spec. The user payload is the MiRO subtracted from the MTPLM.
                            VERTICAL STATIC LOAD/NOSE LOAD
                            The weight imposed on the towball or eye by the trailer coupling.
                            * NB: For the purposes of determining the gross vehicle weight of the towing vehicle, the noseweight of the caravan is included as part of the car's payload. Consequently, the gross train weight is really the sum of the gross vehicle weight including the noseweight plus the axle weight of the caravan, not its total weight. If the noseweight is not included in the vehicle weight but in the weight of the caravan, there is a danger of overloading the car.
                            • loss of pressure
                              back from a long weekend in Blackpool.
                              had a slight problem with the van wondered if anyone had any ideas what it could be,
                              set van up no problems, but then noticed the water pump light kept coming on for a second then going off listened to hear if pump was turning on and it was, i had water both hot and cold and also a good pressure too, no air leaks ok air locks, it seemed to be a gap of 20 seconds or so and then the pump would come on for litterally a second and back off again, checked the whale pump and connections everything seems fine, even spent ages looking to see if we had a water leaks anywhere joints or pipes throughout the whole system, nothing so does anyone have any ideas its a abbey oxford caravan 1998 with the carver water heated, at a complete loss.........
                              • a low battery can cause this to happen. the pump can't spin fast enough to put enough pressure on the sensor and so tops itself up every couple of min's.
                                or the pressure sensor may need adjusting.(it's a small white device on or near the waterheater and has an adjustable wheel on it.
