Jon and me spent some time getting The Vagrant running for Avalanche weekend . Got the engine running but alternator not charging AGAIN . Off with alternator and open up and free off rusty brushes . Then went to fit new front brake pads , ns fine os seized wheel . Thought the pads were stuck to disc but not . Turned out the wheel bearing was rusted solid . Stripped down to find bearing not to clever . Jon went to get a new one but none in stock - order only . So cleaned the old one as best so it turned and then put it back . We thought that would be enough to see us through Avalanche but turns out the clutch is slipping again . Only fitted a new one on the last outing . Seem to run more clutches then anything else .
I now can drop a 410 clutch in 40 mins !
