Hellllloooooooooooooo
[center][font=Microsoft Sans Serif][size=7][color=magenta][u][b][img]http://www.gifs.net/animate/hipgrl12.gif[/img][/b][/u][/color][/size] [img]http://www.gifs.net/animate/hipmn1.gif[/img][/font][/center][center][img]http://homepage.ntlworld.com/jim_ashton/shyAV5.jpg[/img][/center][center][b][color=#ff00ff][size=7][u]E[/u][/size][u][size=5]ms [/size][size=5]&[/size][size=7] J[/size][size=5]im[/size][/u][/color][/b][/center]Tags: None
never know if we get lots of visitors they might letus have a lift down to here
PS is there a zook under all that mudEnjoying Life after Cancer
Pops
Originally posted by popbriscoehi ems & jim. long way down here init? but worth it.
PS is there a zook under all that mudI never ever apologise for anything. http://www.onestopshopformultimedia.com/smile.gif If you dont like it I am sorry but thats the way I am
Originally posted by LindaBut good fun eh?????
How long has this been here? It was not advertised!
I assume that we are allowed to say Suzuki here and it is T****A H***X S**F for our other pride and joys!
As to Hills sorry Lads & Lasses I took our SUZUKI SAMURI SJ413 convertible with hard top option, to a 4x4 meet over here on Sunday.
And I am afraid I let you down a bit But I promise to make it up to you all in due course.
I had to be pulled out of the mud as a Landy had really buggered up the route! it was classed as EASY when I entered the bushy area but but they had upgraded it to HARD by the time I left!I was unable to get over the hill, due to the tow bar digging in (and thats my story and I am sticking to it)
Needless to say I require some Mud Terraine Tyres and a lift (any recomendations?).
PaulDUNNO'S BACK ..........He never really went away!
And I am afraid I let you down a bit But I promise to make it up to you all in due course.I had to be pulled out of the mud as a Landy had really buggered up the route! it was classed as EASY when I entered the bushy area but but they had upgraded it to HARD by the time I left!I was unable to get over the hill, due to the tow bar digging in (and thats my story and I am sticking to it)Needless to say I require some Mud Terraine Tyres and a lift (any recomendations?).
Paul
The main requirements were some small pieces of box section & some solid aluminium spacers drilled in the centre.
Simply lifted the whole of one side of the body with a sleeper & trolley jack & used this stuff to fill the gap.Then did the other side to match
the easiest way to lift a zuki is a SOA (spring over axle) job, they are built with the axle on top of the springs, all you need to do is unbolt it all, get the axles out and refit them under the axle, should all be home built stuff, if you have a grinder and welder to play with.
http://www.off-road.com/suzuki/samurai/ukspoa.htm for the low down.4x4toys.co.uk - Keeping you on and off the road...
Originally posted by TonyNthe easiest way to lift a zuki is a SOA (spring over axle) job, they are built with the axle on top of the springs, all you need to do is unbolt it all, get the axles out and refit them under the axle, should all be home built stuff, if you have a grinder and welder to play with.
Originally posted by luckyThe good thing about that approach is that it shouldn't affect the handling in the same way that lengthened shackles or recurved springs would do. Only thing affecting the handling will be the raised centre of gravity.
I am not sure about the SOA,Tony, as mine is "Her in Doors" run around and the article states that it is not stable after the mod (I am not sure that it is all that stable now).
Originally posted by hormygollopPsst they put us wayyyy down here cos they know we got machines wot can climb hills
and heres a piccy of our/her suzi.
sumo.Last edited by sumo; 17 August 2007, 08:13.If the puddles to deep..LEARN TO SCUBA.
Originally posted by sumoThey might be able to climb hills BUT they cant clime out of HOLES
sumo.
