SJ not starting now
  • SJ not starting now
    Just ttok the Battery out to make the hole in the wing for a snorkle . Whilst i was waiting for the pipes to turn up froma mate , i decided to flush the water system , water went almost everywhere , anyway , put it all back , thn it wouldnt start.
    Im guessing its just shorting somewhere , as when you try to start it . it just clicks then the battery lights go out , and wont trn on again until you disconnect the battery - left it drying in the carport . is that all it needs ?
    http://www.darksidesolutions.co.uk - Web Solutions
    High resistance / poor conection somewhere . Check all cables from battery to starter and chassis .
      you have got the battery connected the right way round???
      (just a thought!)
        Thanks Guys.
        Battery was right way round . Terminal Clamps were in a right state and the earth wire was about the size of fuse wire !
        £6 later I have 2 new connectors and a new earth wire from Halfrauds. And its starts fine.
        Sucking loads of air in from the new Snorkle.
