suki wont start
    Originally posted by stormforce1067
    where abouts is the fuel shut off solinoid please Rick as i aint got a clue
    Did you manage to get it going Rich.?
      hi bushy no not yet i've swapped over the coil put on new leads plugs there's a new rotor arm already on it i got a spark and fuel is getting thru .think iwill have to get some one to take a look at it for me,but thanks everyone for your help
        one thing i just remembered was that the bloke i got the suki off said that the auto choke was a bit sticky but it always started tho
          this is a bit borderline stupid, but when one of my more errr, stuborn motors wont start i stick a little butane blow torch up the air intake (not lit before anyone starts) this makes the mixture slightly more volatile and if its a might start/ might not day, it gets the thing running. it also teaches the car not to mess about in the mornings.
          please note this only works on sulking cars, rather than fixing anything that is wrong with it....
          it's in me shed, mate.
            all else fails, give it a damn good thrashing!
            First you need to look for a suitable branch.
            Basil assaults his Austin 1100. " Right! That's it! You've tried it on just once too often! Right! Well, don't say I haven't warned you! I've laid it on the line to you time and time again! Right! Well...this is it! I'm going to give you a damn good thrashing!"
              That was filmed outside my woodwork teacher house 1 street away from where we lived as kids .
                my wood work teachers looked weird!... one like the ginger dude off planet of the apes... the other looked like a gnome!!
                incidentally... can't you take off the filter and release the choke??... also you'll be able to see what fuel's going in etc. then.
                  theres probably nothing wrong with it just nicotine withdrawl affecting Richards judgement!!!!!!!!!!!!
                  ex Burgundy 2.4 owner
                  • #24
                    had someone take a look at it this evening and is coming back tomorrow to get it sorted.he is going to go thru all the wiring and totally check everything out and says he will have it up and running tomorrow.i will let you know the outcome and what the problem is
                    thanks for all your help guys
                    • #25
                      then get him to pop over and adjust the timing on mine?!... although a bit of fresh petrol would probably be a better fix!
                      • #26
                        i got some spare patches i could stick them over the suki and see if that helps
                        • #27
                          the suki starts at last
                          we got the suki running at long last.although there was a spark it wasnt a good enough spark so we swapped the distributors over and bingo first turn of the key and away she went so thankyou all for the help and suggestions
