Ok guys I now have a nice winch fitted on my transporter. At the moment I just have a little battery to hook up when needed but obviously this will get drained and need charging. Can I hook up some kind of wiring for those with twin electrics so I can charge the battery on the move? Will I be able to have still connected when using the winch also?
I guess I can run some smaller cables to the battery and put a plug on to go in the socket on the car?
I dont have the charging circuit socket on the car yet so i will need to do that too.
Also as the battery will be connected all the time is it worth fitting some kind of switch to disconnect the power when not in use?
Cheers for any advise
