We picked up the new Zook on Sunday. I have some work to do on it. The brake master cylinder seals need replacing as the pedal goes right to the floor. There is no sign of leaking callipers.
The inner and outer sills are shot, so I am on the lookout for some chequer plate replacements. Surprisingly the floor is absolutely solid. The rear arches have been plated.
There is a really rusty o/s wing which has been filled with expanding foam. I will look out for a replacement.
On the plus side it has 6" shackles. On the minus side the shackles look home made and have no brace to tie them together.
It is fitted with Technics Trackers which have plenty of meat on them.
There is a problem with the carb. I think it might be that the slow idle jet is blocked, as there is no inline fuel filter and it will not tickover at less than 1500RPM.
Mrs KS will be back at work tomorrow. I have earned some brownie points by cutting the front and back grass, doing all the weeding and cleaning the moss off the patio. I will take some picks of the beast and have a tinker with it.
