My IS200 interior
  • My IS200 interior
    Hi guys!
    Just wanted to share a result of first modification to my Surf interior
    I don't mean to sound cold,cruel or bitter but I am so that's how it comes out...
    That looks nice and tidy.
    Bet the fronts are more comfortable than the original seats
      They make a world of difference!Before I couldn't last more than an hour of driving,and there's a heating bonus as well
        That's might impressive!
        Did it take a lot to get it to fit in??
          Little bit of fiddling around here and there,previous write ups on forum made it easier (thanks guys!)I think wiring took me the longest :P
            can you tell, which cable is which, for the heating? thanks
              If I remember correctly thick white is power to motors,thick white and black is earth and thin red and green is heater power (utilizes same earth as motors) and there's also slightly thinner blue and black which is seat belt sensor,if you have a pic of your plug that would be easiest
                camera is not the best
                  Are the rear seats out the IS200 too?
                  Looks lovely, I would like to do something similar to mine.
                  l'm FAME-ous!
                    Red and blue is heater and the thinnest one is seatbelt sensor so you won't need it
                    Rear seats are surf seats reupholstered (as you can see from dangling bottom flap still need touching up ) only thing used were alcantara inserts and lexus headrest
                      do you know if they had hi and low settings? thanks
                        Nope, I've used IS200 switches and they're just on and off, don't know if you can use the others to get that function
                          Did the seat rails go straight in without mod or did u have to mod them? My gen 3drivers seat is fooked. Collapsed at back and gives me a bad back. My Mrs has is200 so I suppose I should be trying it out myself lol.
                            I had to bend front ones to right angle and do a bit of welding at the corners and flatten rear ones,also I had to drill two holes for rear one on each side and use M10 bolts with massive washers...Basically I've copied one of forum's members idea But that's 2nd gen so I'm not sure if 3rd is the same but since you have an access to IS200 you can always take measurements and compare them
