If I remember correctly thick white is power to motors,thick white and black is earth and thin red and green is heater power (utilizes same earth as motors) and there's also slightly thinner blue and black which is seat belt sensor,if you have a pic of your plug that would be easiest
I don't mean to sound cold,cruel or bitter but I am so that's how it comes out...
Red and blue is heater and the thinnest one is seatbelt sensor so you won't need it
Rear seats are surf seats reupholstered (as you can see from dangling bottom flap still need touching up ) only thing used were alcantara inserts and lexus headrest
Did the seat rails go straight in without mod or did u have to mod them? My gen 3drivers seat is fooked. Collapsed at back and gives me a bad back. My Mrs has is200 so I suppose I should be trying it out myself lol.
I had to bend front ones to right angle and do a bit of welding at the corners and flatten rear ones,also I had to drill two holes for rear one on each side and use M10 bolts with massive washers...Basically I've copied one of forum's members idea But that's 2nd gen so I'm not sure if 3rd is the same but since you have an access to IS200 you can always take measurements and compare them
