Diesel to Veggie Oil conversion...Help
  • Diesel to Veggie Oil conversion...Help
    Can anyone offer some sensible advice on how to convert my diesel to run on processed veggie oil, I've heard there are various ways...I want the cheapest and most simple...please help!! And also is it a sensible thing to do in the first place I've heard conflicting opinions?!
    Hi,
    I run mine on a mixture, I put 15 litre of Veg oil in, then top up with Global Diesel (5% bio mix from Tesco) - you cannot get any simpler !!!
    Trev
      This has been covered at length already here on the forum, have you read up on all the prior threads, try a search, all the info you require should be there already.
      Maurice
        chris
        visit dieselveg.com they do a diy kit for around 500 pounds
          Newest convert
          Just became the latest convert to the benefits (mostly financial) of veg power!
          I've started by mixing 25% oil to the tank with no loss in power, no noticable difference in engine noise and only a slight change in exhaust odour - it doesn't smell like a chippy but I get the odd whiff of hot veg oil occasionally!
          Thanks to all who posted info and sensible advice on the subject (particularly Morr), early days for me yet, but I think i'll be well happy with the change - once i've got over the embarassment of buying bulk oil from my local supermarkets.
            Is it REALLY as simple as adding a bit of vegetable oil in the normal diesel tank???
            What sort of oil's the best to go for??
            Does it work just as well??
            Sounds a bit too easy to me!!!
            Dave
            It just does, OK?
              Dave
              yep, that simple, i use about 20-25% veg oil this time of year but about 40% in the summer, normal veg oil, 46p a litre at aldi, no probs, runs great
              ship
                rapseed oil normally the best to go for,if it says veg oil and it`s cheap that`s normally rapeseed.
                you can run a 2 tank system,start on diesel and switch to straight veg,but you need to warm veg oil up as it`s much thicker than diesel.
                for 1 tank,mix at least some diesel with my veg oil out side the tank just to start the mix.
                if it`s really cold you may notice a slight lumpyness on start up(or it may have just been my 205d)but that soon clears.
                  Cheaper veg oil!!! check it out
                  Just been shopping and found a new veg oil product. I forget who makes it (maybe CRISP'N'DRY) .
                  It's a spray oil that allows you to use 90 per cent less oil than ordinary cooking oil.
                  So if my maths is correct:
                  1 x 500ml bottle is equivalent to 50 litres of normal veg oil.
                  1 bottle cost £1.99 - where as the equivalent amount veg oil cost £55.00 +
                  The only problem is adding it to the fuel tank. two quick squirts into the tank is all it takes to achieve the correct mix - but in windy conditions - it can blow all down the side of the car.
                  Conducting trial - will report back!!
                    It's only a hobby!
                      Trial conducted and completed with some intresting results.
                      found that during application, the amount of spray oil recommened on the bottle - equated to 4.5ml, which did not register on my fuel gauge.
                      Now thinking back to my college days in chemistry we find that combustion is normally based on the stoiciometric ratio of 14 parts excess air to 1 part fuel by volume.
                      So the spray oil volume being 4.5ml requires a "bulking agent" to increase it's volume.
                      I've found the best agent for this purpose is ordinay deisel fuel sold at most garage forcourts for a reasonable price.
                      by mixing spray oil with deisel at a ratio of 1:2222.2 (or 2 squirts spray oil to 10 litres deisel) gives us a healthy reading on the fuel gauge.
                      Using this mix I've acheived a modest 23mpg.
                      the cost of deisel is offset against the initial saving on the spray oil.
                      A good all round result. the oil companies get their share as do HM C&E, and we eco warriors and cheapskates get to use our beloved veg oil.
                      Happy motoring.
