body lift done and silly girlly steps are off
  • body lift done and silly girlly steps are off
    body lift is now done and silly girlly steps are off
    the lift kit
    befor lift
    after lift
    the girlly steps are off
    no sides lifted
    one side lifted
    two sides now
    the 4WD stick
    the worst part of the job was ....
    removeing the grill
    the 4WD stick
    easyer jobs to
    lowering the rad was a easy one
    front bumper to get off
    http://southcoast4x4club.co.uk
    Marvelous, just needs a good scrub now.
      if anyone is intrested in a lift kit we have loads of poly bar left
      can be cut to length easy on the drop saw pm me for more intrest
      the bolts are stainless steel
        stop swerring at me
        im not washing the smurf
          Now you need to get a nice set of sliders off Yoshie
            im to cheap to buy them ......im in the proess of making some
              im guessing your bolts are A2 or A4 grade.
              keep an eye on them as that kind of bolt is a bit brittle for that job. you can get high tensile stainless but its a wee bit pricey. stainless bolts tend to crack when used in a flex type application - eg a body mount.
              a normal high tensile plated bolt would have been cheaper and stronger.
              they might never break but its worth having a peek at them every now and again especially if you use the truck offroad.
                And the chances of that happening is proble 1000000 to 1
                the SS bolts cost me £12 for all 10
                  Wow, you're a metallurgist as well?
