just given my 2 gen a 2" lift, this evening i adjusted my column and noticed that were it goes thru the bulk head its no longer in the centre of the hole
what adjustments can i do?
Thats normal John.
You can elongate the opening a bit more so it doesen't rub, then you'll need to seal the opening with some rubber sheet or a very large grommet of some sort so you don't get wet feet when playing submarines.
Will you need to cut out for 4wd selector lever? just done mine it now stops in low range.
Normally needs nothing more than a little filing to the opening in the floor to allow the lever to be pulled back into 2H.
Some Surfs don't need it, but most do.
Mine just needed a little bit, it would engage but would not stop there, i needed to hold the lever forward, so i just touched it with the die grinder and all is good now.
Only took 5 mins too.
i didn't notice anything different with the levers
Might be due to how much higher the transmission is with the (coff) ding the crossmember got ?
peace
cal
think you are onto something there, that will be why,. way hay i have a free tranny lift think i should taken a patent out on it and go halfs with mr bala and his big hill
