lifting probs
  • lifting probs
    just given my 2 gen a 2" lift, this evening i adjusted my column and noticed that were it goes thru the bulk head its no longer in the centre of the hole
    what adjustments can i do?
    I was gonna say, we're in our forties what can we do, but thought it would sound crass oO
    peace
    cal
    www.thecellardwellers.co.uk
      Thats normal John.
      You can elongate the opening a bit more so it doesen't rub, then you'll need to seal the opening with some rubber sheet or a very large grommet of some sort so you don't get wet feet when playing submarines.
        Cal did the rubber bit already
        have to get the file out then and come up with some sort of seal
        cheers Vince
          Will you need to cut out for 4wd selector lever? just done mine it now stops in low range.
          My brakes dont work, so i made the horn louder.
            Normally needs nothing more than a little filing to the opening in the floor to allow the lever to be pulled back into 2H.
            Some Surfs don't need it, but most do.
              Mine just needed a little bit, it would engage but would not stop there, i needed to hold the lever forward, so i just touched it with the die grinder and all is good now.
              Only took 5 mins too.
                i didn't notice anything different with the levers
                  Might be due to how much higher the transmission is with the (coff) ding the crossmember got ?
                  peace
                  cal
                    peace
                    cal
                    think you are onto something there, that will be why,. way hay i have a free tranny lift think i should taken a patent out on it and go halfs with mr bala and his big hill
