Hi All
I am thinking about having my 3rd Gen lifted by 2" and I have noticed that you can either lift the body or the suspension. As a complete pen-pusher I have no idea what the difference is and what benefits the two different lifts will give. Ultimately I am trying to lift it for extra clearance to keep things drier when launching a boat.
I know that I risk becoming the laughing stock for asking what is probably a stupid question, but if you don't know - you don't know!!
Simon
Simon
 Suspension/Body Lift difference?
  .) that you would be ok with the standard brake lines etc as its just 2" (on mine the shocks will be at the maximum but nothing else needed)....will be tight but can add the extended stuff later if you arent throwing the truck around off road.
.) that you would be ok with the standard brake lines etc as its just 2" (on mine the shocks will be at the maximum but nothing else needed)....will be tight but can add the extended stuff later if you arent throwing the truck around off road. ..
