Hi all,
My surf runs well and has no smoking problems. From what I've read after doing the EGR mod I will only put my engine at risk if it is running at 'full load' ie: going up a very steep hill loaded up or towing heavy stuff etc...
What I thought would be a good idea would be if I had a solenoid that blocks the egr vacuum pipe (the one that is disconnected on the mod) and opens it with voltage applied. This way I can use a switch in the surf to re-instate the EGR system if I find myself in a situation where the engine will be at possible risk.
I was thinking a 4x4 VSV could possibly do this job.
What do you guys think ?
Rob.
Rob.
