6" body lift HELP !
    Originally posted by surfenstein View Post
    hey rod is that the best excuse you can come up with,just hope trev dont see it. i wont tell him promise.
    shhh!!
      I would like to see some pics of your blocks. I used two sets of 3" blocks and redrilled the four corners of the truck to take 16mm bolts. The six middle blocks were sleeved and redrilled to take 12mm high tensile threaded bar. I did my body lift with no engine or gearbox in so it was easy. You will also need to fab up some 6" bumper brackets, drop the rad considerably, lower your power steering tank and make a lot of changes to the loom and all the other bits that were mentioned in a previous post. You might also want to consider lifting your fuel tank. You will have to lenghthen the filler pipes also.
      If your not put off yet and still want to do it good luck.
      Steve.
      monstercreations.org.uk
        Hi thanks for the advice but I have cut the blocks down to 4.5 inches now as the thought of the body having 6" of flex put me off I will be doing the lift tomorrow so I will post so pics of the job in the next couple of days.
          Do you have any photos of the beast ??
            Yeah here it is there is also a youtube link in the general under this is what Lucifer sounds like.
              And this is the transplant.
