6" body lift HELP !
 I would like to see some pics of your blocks. I used two sets of 3" blocks and redrilled the four corners of the truck to take 16mm bolts. The six middle blocks were sleeved and redrilled to take 12mm high tensile threaded bar. I did my body lift with no engine or gearbox in so it was easy. You will also need to fab up some 6" bumper brackets, drop the rad considerably, lower your power steering tank and make a lot of changes to the loom and all the other bits that were mentioned in a previous post. You might also want to consider lifting your fuel tank. You will have to lenghthen the filler pipes also.
 If your not put off yet and still want to do it good luck.
 Steve.monstercreations.org.uk
