2/3/4" suspension lift?
  • 2/3/4" suspension lift?
    Ok, having taken all previous advice on board, I now have luckily had my brother go to the US so he is able to pick up the Aisin hubs and BJ spacers I ordered recently on the cheap.
    Sledge will be bringing my 2" ES9000's to Monster Mania.
    So the kit for lifting is getting there slowly.
    Plan is to go for Landcruiser Springs to lift 3" and just cope with the fact that the shocks aren't quite the right length. However, I quite like the idea of Roughtrax 2" springs with spacers to make up the extra inch and to save me worrying about the LC springs popping out or having to get location cones for them.
    As I said in previous thread one of my mian concerns was lifting without having to do too much more than the above (I know once you start going over a certain height you have to start tweaking loads of stuff!)
    So, looked out some 1" spacers.... then surprise, surprise, next to the 1" spacers were some 2" spacers for the same money and being greedy this set me to thinking can I do a 4" suspension lift without tweaking too much else?
    I guess I'm, just thinking, 33's are something I may think about in the future, so would a 4" suspension mean that if I wanted to I could fit 33's? yes the +2" shocks wont allow the springs to do all they can but I can always change them later (or will it be a problem to have them 2" different?)
    I've steered away from a body lift as a) if I can do it via a job I'm doing anyway, then the extra inch is easy and b) I seem to remember someone (biohazard?) telling me that the body lift opens up the seam at the rear of the engine bay and allows more water ingress and I like dry feet.
    So... stick with the LC's or go up to 4" sus without having to fiddle too much?
    Sorry, seem to be unable to ask a question without rambling
    My lift consists of Roughtrax springs with 2" spacers. That with the 1.5" body lift is enough for me to squeeze on 35"s.
    There is a slight indentation from the upper O/S trail arm on the fuel tank. Not a huge amount.
    It does pull the rear axle forward an you will want to upgrade to extended braided brake lines.
    Im happy with it for what its worth. Your doing Monster Mania aint ya?!
    Take a look at it then mate.
      Jesus! 35's! calm down. i cant go that high! I'll never make it up hills!
      Thanks Rod, Look forward to seeing your truck at MM!
      Only a week now!
        Originally posted by biosurf View Post
        .............................. .............................. .................... I seem to remember someone (biohazard) telling me that the body lift opens up the seam at the rear of the engine bay and allows more water ingress and I like dry feet.
        EH???????????????
          Memory is admittedly hazy but I'm sure someone told me that the rear of the engine bay does get moved with a body lift and this creates an opening that water can come through (if you happen to be driving through the particualrly deep stuff! )
          This could be a case of me mis-hearing/remebering and if I'm wrong thats certainly no bad thing
            A bodylift lifts the body away from the engine and gearbox to allow better airflow which aids cooling.
            No 'seal' has been broken to allow water ingress.
              Only a week now!
              I wasn't suggesting you get 35" tyres! An you can make it up hills..
              I was just saying that with that set up you could easily get 33's under there.
              Dependant on offsets an rim width
              an i know!! could do with making it two weeks but then i'd miss reading festival!
                dammit, don't talk to me about festivals, havent made it to one this year
                Anyway I' only jealous about the 35's
                sort of
                  sort of
                  Not sure what your taste in music is but Download this year looked a bit on the um... poor side.
                  Just managed to get some Sunday reading tickets, the decent bands are playing that day!
                  Metallica, Slipknot, Tenacious D etc
                    slipknot will be good to see, pimpin their new material no doubt
                    back on topic, im looking into lifting my new toy as well. Are +3" shocks available for the back to match the LC springs..?? Or is it better just to stick to a surf spec +2" set-up.
                    As for the front i was going to fit uprated torsion bars and equivelant shocks to get the truck sitting level. Then i plan a 2" body lift with a kit from Stein, should be happy with the look and performance of it then
