Option 3 sounds best, if only for the helo ride
The cheapo option (2" sus / 2" body) gives you clearance for 33s, and leaves you around £500 from your grand for underbody protection, so then you not only get cool looking 33s, and some more underside clearance, but well shaped underbody plates will mean you can use the truck as a sled!
Everybody wins!
I dont know if 2" sus gives you enough clearance for 33s, but Rod Leach has got the 2" + 2" (or 3" at a stretch) and has 35s. If you just want snow traction and a bit more clearance, but aren't expecting to need lots of articulation, the 33s might just fit. See if you can borrow some...
Everybody wins!
