Been at it again today, just stuck it on top for a pic to give some idea of how big it is compaired to the engine, i've since removed both air pipes and it will sit a little lower than the pic but not much,
one question for you guys who've fitter one is- i assume you just reconect the small tubes? (pic of the EFI part in the vice) together, this part has a small steel pipe welded to it and the small hoses connect either side, thinking of replaceing it with one longer tube this sound OK?
Another question is can i start the engine with turbo disconnected, in my rush to get started on this i forgot i needed to back the truck out to remove my pit boards, as this will be a good time to remove the AC stuff and i'm gonna need to get under it, i would only need it idleing and dont intend to rev it enough for the turbo to come on, but even so it'll only be pushing air to nowhere, cant see a prob but though i'd ask
