any one know of an engineering firm that can do precision laser cutting in s/steel.? i fancy fabbing up one of those plates that weld on the rear axle from the diff housing along the axle tube,but i wanna get surfenstein cut into the plate first.any one know what im on about?
laser cutting.
yea you could be right,either one will do the job,but i think water cutters are fairly new arnt they,so im just wondering wether most companys have that sort of technology at their finger tips,actually thinking about it plasma cutting would give it that rough edge look,might look better that way.www.overfab.uk
parker steel in andover do laser and water jet but i think they like to have a good cad drawing supplied otherwise you will end up paying there guy to do it. www.parkersteel.co.ukOriginally posted by vatchmanany one know of an engineering firm that can do precision laser cutting in s/steel.? i fancy fabbing up one of those plates that weld on the rear axle from the diff housing along the axle tube,but i wanna get surfenstein cut into the plate first.any one know what im on about?
you certainly can heres one i did earlier.Originally posted by NismoYou can weld stainless to mild no problem at all.
Best to use a stainless filler wire & remember that mild has a higher melting point than stainless. Stainless is a lot less maleable than mild steel but will actually shrink more than mild once heated hence the welds "can" crack as the 2 steels are cooling & shrinking at different rates. If you know what you're doing though it shouldn't cause a problem.
