Disassembling viscous fan
  • Originally posted by ian619
    4 if any of the above sounds viable where's the best place to stick it,
    That's a dangerous question to ask, ain't it Ian?
    (The Bushy will be mine............... Hahhahahahahhahah. . . cough)
    • Originally posted by stormforce1067
      yea but anyone else comes in now then they got a bit of catching up to do...............Bring it on yea yea yea
      Everyone's got a lot of catching up to do with you, Richard. You got three
      in one week at one point.................. Shocking.
      One shall, however, prevail.
      • With regards to adding an extra electric pump to the system, that would
        probably cause rather than cure problems. I know some have replaced the
        mechanical water pump with an electric one, but running both together
        might cause a problem. Have you got a picture of one? I could also be
        completely wrong again.
        • Originally posted by MattF
          Just waitin for the smartarse reply on that one
          Oh all right then!! i would.nt know what to do with it anyway
            Trust me, the first time you get one, you'll be that overawed, you won't care
            if it's useful or not.
              well if you need a diagram or instructions Ian you only have to ask but its a family forum
              is this worthy of another Bushy Bonus
                Yeah you could be right, the reason i asked is we fitted these pumps in addition to the busses engine pump as that was haveing trouble pumping it all the way to the front of the bus,
                Thinking about it there may be problems with the circulation being too fast and not haveing time to cool in the rad, i dont know,
                Was thinking of plumbing in another rad where the air-con cr@p is, when i get it out!
                  Battle stations.
                    Battle stations.
                      That could actually be worth working out a way to have one of those
                      thermostatic type valves open up and start the pump to direct some
                      flow through a secondary radiator. That wouldn't be interfering with
                      the mechanical flow, if it was setup right. I'll see if I can find any info
                      on that type of idea.
                      • If the coolant is flowing too fast, it won't stay in the radiator long enough to be cooled.
                        • Originally posted by BUSHWHACKER
                          If it was regulated, (running at half voltage might work ), might not be
                          too bad an idea, though. Same type of principle as the engine and ATF
                          ancillary oil coolers. Found out the boxster has a multi rad setup.
                          http://www.bombaydigital.com/boxster/projects/radiator/
                          • Thats why i wondered if a 24v motor ran half speed on 12v and would it pull too much amperage (?) or not,
                            thats a complicated system on the boxster,
                            Once i can start work on the truck again i'll get the aircon stuff off and have a measure up to see what size rad will fit in there, if i do the 2" lift that'll give me a bit more room,
                            I'll get a pic of this pump tomorrow,
                              For years basic D.C motor speed controllers merely varied the voltage, so
                              it may. Depends upon the motor. As to current, what rating is the motor?
                                I'll get a pic posted tomorrow and quote the info off its plate,
                                BTW is there a minority report censor on the forum?
                                Posted a reply to richards offer of a diagram and instructions Twice and it aint taken, so i guess they can tell if you intend to get too near the mark,
                                OMG they can read my mind,
