Turbo Boost Question
    Originally posted by TonyN
    The turbo is harder to reach, but the setup is the same so I guess so.
    The 3.0 runs higher pressure, 7.4 to 9.7psi stock, FYI.
    These are "no Load" figures (see attached) on the road you will see a couple of PSI more under load the factory ECU map will have some "headroom" to allow for variation between engines but I'm not sure how much. Be careful of adding too many washers; the wastegate diaphram has a limited stroke and it's not a good idea to reley on the ECU protecting your engine. If you want to play buy or make a bleed valve and add a boost gauge so you can see how far you've gone and an EGT gauge to make sure you don't cook your engine. (Westach do both; aircraft quality car prices)
      Originally posted by Apache
      Damned electronics! You knew where you were with a screwdriver and a hammer!
      Now you use a pair of wire cutters too.!!!
      My 2.$ is non-EFI
      No EGR and associated wires and $hit
      No throttle butterfly
      11psi boost...........gauge on the A- pillar
      A straight out mechanical motor for me !!!
      Simon.O.
      '90 SSR Ltd 2.4TD 5 spd
