I have put 3 x 1mm washers behind turbo waste gate and all is running fine but wondered what would be the safe maximum for this. Can I squeeze another 1 or 2 mm on to this or would this be pushing my luck and heading for top end damage. Any advice appreciated.
Turbo Boost Question
Originally posted by dirtydogthe engine should prevent you from overboosting anyway - best to keep an eye with a boost gauge though. ive been on 1mm for a year or so and 2mm for the last month.
I have got 5 1mm washers behind my waste gate and touch wood all is ok boost on my cheapo Tim boost gauge boosts to 0.8 bar and holds just below that i have seen some cummins diesel engines have boost gauges that top out at 60 psi. i think its on the 7.4 liter power stoke thats in the American Ford 2500 i want to run more boost in mine 25psi should do it?
On a motor thats supposed to run at 5.5 to 7.3psi............Originally posted by christopoher murphyi want to run more boost in mine 25psi should do it?
Good luck, my numbers on my website when you want the engine rebuilt.
The chaps at Fensport used to run a GT4 at something stoopid like 38psi! Mind you, the owner did say he carries a boot full of head gaskets round with himOriginally posted by TonyNOn a motor thats supposed to run at 5.5 to 7.3psi............
The turbo is harder to reach, but the setup is the same so I guess so.Originally posted by ApacheI note that's a 2.4, as are all of the vehicles in this thread. What about the 3.0? Same process?
The 3.0 runs higher pressure, 7.4 to 9.7psi stock, FYI.
