I'll start this off then.....
  • I'll start this off then.....
    I've made a few changes since getting the 4runner. Mostly in the fuel system etc by way of a Zavoli LPG fuel injection system and 2 x 50 litre LPG in place of the old winch down spare wheel carrier underneath the rear of the truck. - unfortunately all this added extra weight to an already soggy r.send so on Tony's advice I went for :-
    2" lift springs
    4 x Pro-comp ES 900 Nitrogen Gas Shocks
    Made one hell of a difference, rear end doesn't sag (even under load) handles brilliantly. V.V.PLEASED!!!!
    Ranger 5 spoke Alloys with BFG A/T's 31x10.50x15
    2 x Rinder Spots 100w
    2 x Rinder Fogs 100w
    4 x marker lights (sad I know - I guess it's that little bit of trucker in me still)
    4 x white strobes
    2 x alternating rear reds
    (the above are for work and rallying etc - see my profile for explanation)
    Sony Single CD Head unit
    Alpine T300 amp
    Alpine F250 amp
    Jensen sub (it was a freebie)
    I left all the original Toyota speakers in but added better wiring and for a stock amplified system is bl**dy loud
    EGR window deflctors all 'round and an EGR sunvisor deflector too.
    Bonnet guard (courtesy of Sumo!!)
    Tow point on front
    Bash plate/sump guard
    LPG bash plate
    Air Pipe Mod
    Iridium plugs
    Next step is to change the brake lines for braided hoses,
    NO WORRIES!
    Rusty
    Originally posted by rusty
    I've made a few changes since getting the 4runner. Mostly in the fuel system etc by way of a Zavoli LPG fuel injection system and 2 x 50 litre LPG in place of the old winch down spare wheel carrier underneath the rear of the truck. Then put a home built swing aside spare carrier on the back - unfortunately all this added extra weight to an already soggy r.send so on Tony's advice I went for :-
    2" lift springs
    Added
    4 x white strobes
    Sony H/U
    Alpine T300 amp
    Alpine F250 amp
    Jensen sub (it's was a freebie)
    Next step is to change the brake lines for braided hoses, put wheel spacers on to push the width out a bit and change the tyres for some BFG A/T's (as big as I can get on stock alloys), weld a towing/pulling point on the front with a shackle attached, bonnet guard (courtesy of Sumo!!)
    Guess I'll post some things too.
    I hevn't made many changes to mine apart from the following.
    1. Arrigoni and De Angelis Roof rails(fitted from above with Rivet nuts and bolts). Thule Roof Bars and a Thule Standard roofrack are fitted to these.
    2. Replaced the Stereo first with a JVC Single din unit then pulled this out and replaced with a Sony WX C570R double Din CD/Tape/Radio unit.
    3. Ring Microline Driving lights fitted below the bumper in the lower cutout and covered with custom grill material - good pattern and quite long range even with 55watt bulbs.
    4. Ring projector fogs to be fitted in the valance under the bumper indicators. Got to cut the valance, make up some brackets, fit them and then make grill inserts to make it look pretty.
    5. Load area cover from www.carseatcovers.co.uk covers sides, seats, floor.
    6. GPS system fitted to car. System is TomTom Navigator running on my IPAQ 3850 and fitted using a Arkon swan neck mount. I have an external antenna to fit, just running on the TomTom one put on the dash at this time.
    7. Replaced the original tyres with Bridgestone Dueller HT 265/70/15 road biased tyres as this is an every day car for work.
    8. Will replace the shocks and rear springs eventually but as the rear isn't sagging got better things to do at the moment.
      Sounds like some nice work has been going on. Good descriptions too. How about some nice pics so we can see what you have done. All this activity makes me feel like a real slouch
      It's only a hobby!
        Phil.
        I'll be posting some pics and writeups when I get round to it, however I've been DIYing (on the house) for most of the summer and I better get it finished first or I'll be ending up on DIY SOS.
          Originally posted by lucky
          Phil.
          I'm having PC/USB problems - am in the throws of upgrading etc will post ASAP
          NO WORRIES!
          Rusty
            1990 SSR Limited / Gunmetal Grey
            Body
            31-10.5 R15 Falken RV Tyres on standard polished chrome rims
            Factory Toyota towbar with removable hitch
            Alloy nudge bar
            2 Hella 20/20 150mm 150Watt Spot lights
            2 Ring dual beam White/Yellow 55Watt driving lamps
            2 Narva 150W Roof mounted spots
            Orange marker lamps on roof rack
            For those not into maths that is a whoop-ass 1000W plus of potential forward lighting
            Rear repeater lamps Turn/Tail/Brake on rear roof bar
            Custom fitted ( by me ) Heavy duty roof rack riveted to roof
            Engine
            2.4 TD
            EGR valve disabled
            Blow-by air/oil separator
            Turbo adjusted for higher boost
            Air intake opened up....this you just have to try!!
            Adjustable Turbo timer
            Electrical
            Two 650CCA Main engine batteries
            One 12Vdc 6.5Ah Gell cell for standby power and radios, alarm etc
            A self contained portable jump-start pack in the back
            Self-designed/fabricated automatic battery management system
            Inside
            Rear cargo locker thing made from 15mm Triboard and upholstered
            Alpine CD/Tuner
            Uniden Pro510 HF Radio
            Uniden UH053 UHF Radio
            Uniden Bearcat 200 Scanner
            Garmin GPS
            Tinted glass all round, well the rear side ones are painted black from the inside, looks very nice!!
            Mods to come
            2” suspension lift
            1-2” Body Lift
            Raised side steps
            Heavy alloy bash plate
            Low profile transfer case cross-member
            Front and rear Diff lockers
            Snorkel ??? I hope SHE will let me!!
            Simon.O.
            '90 SSR Ltd 2.4TD 5 spd
              1997 (R) 3rd Gen ssr-x
              dark blue/silver
              TOAD A606i cat 1 alarm/immobiliser rear window control, microwave, ultrasonic etc. etc.
              2" 4crawler bodylift
              265/70-16 Colway M/Ts on 7x16 steel chrome wheels
              4 blue driving lamps in grille
              Fitted Kenwood Mp3/CD
              Fitted 2 Amps 1x 300w 2 way bridged running 10" sub
              1x 350w 4 way running front Alpine 5" 2 ways
              rear Infinity reference 3way 6x9s
              (gotta make a little box to put them in so they don't get nicked!)
              GPS running on Ipaq pocket pc with tomtom navigator
              removed foglight and re-wired to make o/s reverse light into fog
              60a power to boot (mainly to run amps) cig lighter socket etc.
                1994 3.0 TD - Black & Red (oxide!)
                Body
                ARB Deluxe winch bullbar
                Custom roofrack (basically a sheet of 8x4 marine ply bolted to 4 Thule roofbars!)
                Removed the wheel arch flares.
                Engine
                3.0 TD - new head etc.
                SAFARI snorkel - raised air intake
                Re-built radiator: 5 core.
                Removed viscous coupling.
                Electrical
                OPTIMA batteries (one red, one yellow) with a split charge system
                2 x IPF 800 series spotlights
                Inside
                Rear cargo draws made from 12mm ply
                Lost the back seats and now have 7 jerrycans instead!
                Garmin III plus GPS
                Engel 40L fridge
                Wheels & Suspension
                Old Man Emu (HD) Nitro-charger shocks and HD springs (50mm lift)
                750.16 Michelin XZLs on Landcruiser steel split rims (The true 31" tyre)
                Other
                Alloy bash plate - care of Rusty
                Howling Moon Rooftent and shower skirt
                Lots of Black Rat recovery kit
                @africa4x4cafe
                [url]www.africa4x4cafe.com[/url]
                  WHAT! NO KITCHEN SINK
                    No - but there is a 12v shower attachment!
                    @africa4x4cafe
                      What couldn't you get the sink to fit in then Jeremy.
                      Have you got the rad fitted yet, does it look like it'll do the job, be interested to see it.
                        I hope all goes well for you on your expadition mate. ive read some horror stories about crossing the sahara, everyone got home safely though
                          Completed the 300mile plus trip to see my folks - two **** stops and 60 plus all the way. Well, as usual the thermostat just stays dead in the centre of the dial - no change there then. The top of the rad was still hot to the touch, but not excessively so, and after the vehicle had been sitting awhile I checked the coolant level and it looked just about the same.
                          I went via a public weigh bridge and the truck came in at 2630 kg all in as I was carrying all my recovery gear, tyre repair tools and fridge etc, a 100 kg plus over the recomended GVM. I also had the large roofrack, rooftent, two Michelin XZLs and two (1.25m) aluminium sand plates strapped to the roof - therefore providing the aerodynamics of a blunt brick ****house - so all in all I think it passed the test with flying colours. Without all my expedition kit I'm sure it'd cruise at 70-80, all day, no problem.
                          The only minor "problem" is the noise - as the fan's running all the time the 3.0 diesel now sounds like a 4.0 petrol! It also didn't help that my spare wheel was in use (military "studded" XZL for icy conditions) and that tends to make a real "crunching" noise as it runs.
                          I must admit that my once lovely 4Runner is now starting to look a bit like the ******* child of LandRover and Toyota (but without the oil leaks!) but it's my baby and I love it! The wife in Zim has got my digi camera so you'll have to wait for pics until I can annoy my nephews enough and by the way - if anyone wants to buy a perfectly good viscous coupling unit...
                          @africa4x4cafe
                            Hey what's this? Some ******* electrickery has ******* censored my post of all ******* expletives! ***, *****, ********!
                            @africa4x4cafe
                              ****** grt aint it mate. we have youngsters & ladies viewing the site so its censored. U not XXX
