Wheel Spacers
  • Wheel Spacers
    Just found this site that sells decent spacers.
    Not a bad price and free postage too!
    Looks like the place is based near Salisbury.
    Hope this helps anyone who is after some.
    Cheers,
    Darren
    So many toys-So little cash
    anybody tryed these spacers because £63 is a good price.
    there was a thread a while back where people were warning against cheap spacers.
    if there is any positive feedback on this i may be tempted.
    cheers scotty
      Delta mic's are the brand I've been fitting for people that came from Trackstore, they work fine, but not normally that cheap.
        Yeah, £63 sounds good, but it's for a set of 2! So, you need 2 sets, £126, which still ain't bad, considering most places are around the £150-160 mark...
        It just does, OK?
          cheers scotty
          If some forum members chip in and buy me a set,i'll gladly relay some feedback on quality and performance.!
            thought it was to good to be true.
            how much are the ones from trackstore coming in at tony?
            as you say dave £126 still isnt bad, wonder what the quality is like?
            cheers scotty
              cheers scotty
              Trackstore are MIA, there was a thread about it recently, think they might have gone bust. The quality is good, they are the same brand Trackstore and others supplied. I've fitted about 3 sets for people lately.
                Yep they gone now
                Tony fitted mine, made a great difference to the handling
                Cheers Tony.
                From what I have heard the steel machined spacers are the ones to go for, not the cast alloy ones.
                Trev
                  wheel spacers
                  i got a set of 32mm spacers for my truck abt 2 weeks ago i only paid £60 i hav had no probs with them i hav been off roading and day 2 day use and they r fine.
                    What sort are they and where'd you get em?
                      I might be being a bit thick here (please feel free to give me a slap)
                      But doesn't fitting wheel spacers put more strain on the wheel bearings.
                      I have always been told, with my other 4x4's that if you want a wider track then you should fit wheels with a larger offset.
                      Is it the same for the surf or is fitting decent spacers Ok???
                      ta
                      hawaii
                        ta
                        hawaii
                        You not thick, just a little misimformed, wheel spaces or wider bigger offset wheels will both stress the bearing more than standard, as the edge of the tyre is further away from the bearing resulting in greater leverage working on the bearing. The only way to keep it balenced is if the offset is reduced, keeping the middle of the tyre over the hubs, but then it would rub on the wishbones when you turned.
                        But, its not that extra stress for the size of spacers we're talking about here.
                          Chers Tony - glad you are here.
                          Always avoided spacers before but will defo have a re-think now as I want to keep the original alloys as they suit the truck, just want a bitter more aggressive stance.
                          cheers for the advice as always
                          hawaii
                            im looking for spacers aswell, are the alloy 32mm ones really that bad, as the only steel ones ive found are 30mm (hmm whats 2mm between friends)
                            Mat..
                            All things Lexus...ask moi
                              there is a full set of 4 wheel spacers on that there site wot flogs things,£44 + £10 postage,dont know if they any good tho
