Just found this site that sells decent spacers.
Not a bad price and free postage too!
Looks like the place is based near Salisbury.
Hope this helps anyone who is after some.
Cheers,
Darren
Cheers,
Darren
wheel spaces or wider bigger offset wheels will both stress the bearing more than standard, as the edge of the tyre is further away from the bearing resulting in greater leverage working on the bearing. The only way to keep it balenced is if the offset is reduced, keeping the middle of the tyre over the hubs, but then it would rub on the wishbones when you turned.
