This is the fastest, cheapest and most effective, for its time/dollars input, to get a bit more go out of the 2.4LT
Mine is a 1990 SSR Ltd,
Stand on the Left side beside the airfilter, probably eaiser to open the bonnet first!!
Closest to you is a rubber elbow which connects the air filter housing to the airbox connecting tube.
Release the clamps on this elbow and remove the tube that goes to the airbox.
Done !!
You WILL notice a difference in get up and go!!!!!
Further refinements
1. Place a short length (about 4" long) of perforated drain tube in the elbow facing forward, this helps to reduce the induction noise from the air filter
2. If you are worried about water etc getting in then turn the elbow over to face the back, this does make for a bit more noise.
My next step will be to face the elbow upwards and fit it with a rubber donut seal to mate with the underside of the bonnet.
Chop a hole in the bonnet and fit a low profile air scoop to blow cool air in, then fit two vents at the rear of the bonnet to help with hot air flow out of the engine bay which in turn allows more air through the radiator.
Done !!
Further refinements
