I have a 3.0L TD surf - the ride seems pretty sloppy even with the suspension on hard - After looking through the forum it seems that replacing the rear springs is the way to go - the question is - should I replace the shocks too? will replacing them help stiffen up the ride?
is it worth replacing both front and rear sets? will this help with the handling etc??
or as they are not leaking and seem to do their job (i.e. dampen the movement) will replacing the springs alone be enough?
if it is a good idea to replace the shocks - can you buy stiffer ones?
